zll@zll-ThinkPad-E420:~$ cd ~/GEOS-Chem-Libraries/src
zll@zll-ThinkPad-E420:~/GEOS-Chem-Libraries/src$ make PREFIX=/home/zll/lib
if [ -f zlib-1.2.6/zlib-1.2.6.install ] ; then \
echo '====> ZLIB has already been installed!'; \
else \
cd zlib-1.2.6 &&\
./configure --prefix=/home/zll/lib --static --64 &&\
touch zlib-1.2.6.config &&\
make check &&\
make install &&\
touch zlib-1.2.6.install &&\
echo '====> ZLIB was installed successfully!'; \
fi
Checking for gcc...
Building static library libz.a version 1.2.6 with gcc.
Checking for off64_t... Yes.
Checking for fseeko... Yes.
Checking for unistd.h... Yes.
Checking for stdarg.h... Yes.
Checking whether to use vs[n]printf() or s[n]printf()... using vs[n]printf().
Checking for vsnprintf() in stdio.h... Yes.
Checking for return value of vsnprintf()... Yes.
Checking for attribute(visibility) support... Yes.
make[1]: 正在进入目录 `/home/zll/GEOS-Chem-Libraries/src/zlib-1.2.6'
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -I. -c -o example.o test/example.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o adler32.o adler32.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o crc32.o crc32.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o deflate.o deflate.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o infback.o infback.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o inffast.o inffast.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o inflate.o inflate.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o inftrees.o inftrees.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o trees.o trees.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o zutil.o zutil.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o compress.o compress.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o uncompr.o uncompr.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o gzclose.o gzclose.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o gzlib.o gzlib.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o gzread.o gzread.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -c -o gzwrite.o gzwrite.c
ar rc libz.a adler32.o crc32.o deflate.o infback.o inffast.o inflate.o inftrees.o trees.o zutil.o compress.o uncompr.o gzclose.o gzlib.o gzread.o gzwrite.o
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -o example example.o -L. libz.a
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -I. -c -o minigzip.o test/minigzip.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -o minigzip minigzip.o -L. libz.a
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -I. -D_FILE_OFFSET_BITS=64 -c -o example64.o test/example.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -o example64 example64.o -L. libz.a
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -I. -D_FILE_OFFSET_BITS=64 -c -o minigzip64.o test/minigzip.c
gcc -O3 -m64 -D_LARGEFILE64_SOURCE=1 -o minigzip64 minigzip64.o -L. libz.a
./minigzip: 1: ./minigzip: Syntax error: "(" unexpected
*** zlib test FAILED ***
make[1]: *** [teststatic] 错误 1
make[1]:正在离开目录 `/home/zll/GEOS-Chem-Libraries/src/zlib-1.2.6'
make: *** [zlib] 错误 2
ubuntu12.04下安装netcdf4.2报错,请前辈帮我看看是什么原因?
- 系统: Ubuntu12.04
- 系统: CENTOS
Re: ubuntu12.04下安装netcdf4.2报错,请前辈帮我看看是什么原因?
楼主,我现在也在安装netcdf4.2,能将GEOS-Chem-Libraries打包发给我吗?我这里网速太慢。谢谢啦
- 系统: CENTOS
- 系统: 12.04 LTS
请问,楼主问题解决了没阿?我也装不成功阿,快崩溃了
