administrator@ubuntu:/opt/etherlab$ sudo rm -rf /etc/init.d/ethercat
administrator@ubuntu:/opt/etherlab$ sudo ln -s /opt/etherlab/etc/init.d/ethercat /etc/init.d
administrator@ubuntu:/opt/etherlab$ insserv
insserv: warning: script 'K20acpi-support' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0 6) of script `umountroot' overwrites defaults (empty).
insserv: warning: current start runlevel(s) (0 6) of script `umountfs' overwrites defaults (empty).
The script you are attempting to invoke has been converted to an Upstart
job, but lsb-header is not supported for Upstart jobs.
insserv: warning: script 'network-interface' missing LSB tags and overrides
insserv: warning: script 'network-manager' missing LSB tags and overrides
insserv: warning: script 'plymouth' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0) of script `halt' overwrites defaults (empty).
insserv: warning: current start runlevel(s) (6) of script `reboot' overwrites defaults (empty).
insserv: warning: script 'gdm' missing LSB tags and overrides
insserv: warning: script 'dbus' missing LSB tags and overrides
insserv: warning: script 'dmesg' missing LSB tags and overrides
insserv: warning: script 'alsa-mixer-save' missing LSB tags and overrides
insserv: warning: script 'hwclock' missing LSB tags and overrides
insserv: script 到 ethercat 的链接: service ethercat already provided!
insserv: warning: script 'plymouth-stop' missing LSB tags and overrides
insserv: warning: script 'hwclock-save' missing LSB tags and overrides
insserv: warning: script 'console-setup' missing LSB tags and overrides
insserv: warning: script 'network-interface-security' missing LSB tags and overrides
insserv: warning: script 'rsyslog' missing LSB tags and overrides
insserv: warning: script 'acpi-support' missing LSB tags and overrides
insserv: warning: script 'irqbalance' missing LSB tags and overrides
insserv: warning: script 'apport' missing LSB tags and overrides
insserv: warning: script 'acpid' missing LSB tags and overrides
insserv: warning: script 'cron' missing LSB tags and overrides
insserv: warning: script 'atd' missing LSB tags and overrides
insserv: warning: script 'avahi-daemon' missing LSB tags and overrides
insserv: warning: script 'hostname' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0 6) of script `sendsigs' overwrites defaults (empty).
insserv: warning: current start runlevel(s) (0 6) of script `umountnfs.sh' overwrites defaults (empty).
insserv: warning: script 'screen-cleanup' missing LSB tags and overrides
insserv: warning: script 'ecryptfs-utils-restore' missing LSB tags and overrides
insserv: warning: script 'plymouth-splash' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0 6) of script `cryptdisks-early' overwrites defaults (empty).
insserv: warning: script 'plymouth-log' missing LSB tags and overrides
insserv: warning: script 'anacron' missing LSB tags and overrides
insserv: warning: script 'udevmonitor' missing LSB tags and overrides
insserv: warning: script 'failsafe-x' missing LSB tags and overrides
insserv: warning: script 'procps' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0 6) of script `wpa-ifupdown' overwrites defaults (empty).
insserv: warning: script 'module-init-tools' missing LSB tags and overrides
insserv: warning: script 'realtime' missing LSB tags and overrides
insserv: warning: script 'udev-finish' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0 6) of script `networking' overwrites defaults (empty).
insserv: warning: script 'udev' missing LSB tags and overrides
insserv: warning: script 'cryptdisks-enable' missing LSB tags and overrides
insserv: warning: script 'udevtrigger' missing LSB tags and overrides
insserv: warning: script 'ufw' missing LSB tags and overrides
insserv: warning: current start runlevel(s) (0 6) of script `cryptdisks' overwrites defaults (empty).
insserv: warning: script 'cryptdisks-udev' missing LSB tags and overrides
insserv: warning: script 'ecryptfs-utils-save' missing LSB tags and overrides
insserv: There is a loop between service rsyslog and pulseaudio if stopped
insserv: loop involving service pulseaudio at depth 3
insserv: loop involving service rsyslog at depth 2
insserv: loop involving service udev at depth 1
insserv: loop involving service dbus at depth 2
insserv: exiting now without changing boot order!
administrator@ubuntu:/opt/etherlab$ sudo /etc/init.d/ethercat start
Starting EtherCAT master 1.5.0 WARNING: All config files need .conf: /etc/modprobe.d/emc2, it will be ignored in a future release.
FATAL: Error inserting ec_master (/lib/modules/2.6.32-122-rtai/ethercat/master/ec_master.ko): Invalid argument
failed
start出现问题 :Invalid argument
- 系统: ubuntu kylin
Re: start出现问题 :Invalid argument
兄弟最后搞定咯吗,你是在研究ethercat吗?
