 文章标题 : 求助,ubuntu14.10配置tomcat后浏览器打开没有猫
帖子发表于 : 2015-02-24 14:55
注册: 2015-02-24 14:33
系统: ubuntu14.10
[/b]terminal提示Tomcat started.但打开浏览器没有猫
tomcat路径:/usr/project/apache-tomcat-8.0.18
jdk路径:/usr/project/jdk1.8.0_31
/etc/profile配置:
#set environment
export JAVA_HOME=/usr/project/jdk1.8.0_31
export JRE_HOME=/usr/project/jdk1.8.0_31/jre
export ANT_HOME=/usr/project/apache-ant-1.9.4
export TOMCAT_HOME=/usr/project/apache-tomcat-8.0.18
export CLASSPATH=.:$JAVA_HOME/lib:$JRE_HOME/lib:$CLASSPATH
export PATH=$JAVA_HOME/bin:$JRE_HOME/bin:$JAVA_HOME:$PATH:$ANT_HOME/bin
Tomcat路径下 ./bin/startup.sh配置:
#set environment
PATH=$PATH:$JAVA_HOME/bin:$JRE_HOME/bin
CLASSPATH=.:$JRE_HOME/lib/rt.jar:$JAVA_HOME/lib/dt.jar:$JAVA_HOME/lib/tools.jar
Tomcat路径下 sudo ./bin/startup.sh启动提示:
Using CATALINA_BASE: /usr/project/apache-tomcat-8.0.18
Using CATALINA_HOME: /usr/project/apache-tomcat-8.0.18
Using CATALINA_TMPDIR: /usr/project/apache-tomcat-8.0.18/temp
Using JRE_HOME: /usr
Using CLASSPATH: /usr/project/apache-tomcat-8.0.18/bin/bootstrap.jar:/usr/project/apache-tomcat-8.0.18/bin/tomcat-juli.jar
Tomcat started.
换过端口为8888
./conf/server.xml
<Connector port="8888" protocol="HTTP/1.1"
connectionTimeout="20000"
redirectPort="8443" />
真心不知道哪里出问题了,求助求助......
 文章标题 : Re: 求助,ubuntu14.10配置tomcat后浏览器打开没有猫
帖子发表于 : 2015-02-24 18:38
接收感谢: 1923
參閱
https://help.ubuntu.com/14.04/serverguide/tomcat.html
帖子发表于 : 2015-02-26 13:45
系统: ubuntu14.10
认真读启动提示,JRE_HOME是不正确的,解决
sudo gedit ./bin/catalina.sh
文件开头
