发表新帖 回复这个主题  [ 1 篇帖子 ]
 文章标题 : ubuntu新手,出现问题了,求大神指点
帖子发表于 : 2013-08-10 10:47
注册: 2013-08-10 10:26
系统: ubuntu13.04
在使用cmake生成makefile文件的时候,已经安装了cmake ,make等软件,但是一但在终端里输入cmake .时就会出现下列问题,
-- The C compiler identification is GNU 4.7.3
-- The CXX compiler identification is unknown
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
CMake Error: your CXX compiler: "CMAKE_CXX_COMPILER-NOTFOUND" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
-- Configuring incomplete, errors occurred!
我曾试过将cmake卸载了重新装过,但仍然出现这个问题,跪求大神指点!!!
