发表新帖 回复这个主题  [ 1 篇帖子 ]
 文章标题 : 这如何解决呢?还有就是开机出现 win7win7win7..一排列下来最后是什么引导什么的,这怎么处理啊
帖子发表于 : 2015-04-21 17:39
注册: 2015-04-21 17:36
系统: win7
#This file is modified at runtime by bootmenu.nsh
set default=0
echo "Completing the Ubuntu installation."
echo "For more installation boot options, press `ESC' now..."
if sleep --verbose --interruptible 5 ; then
set timeout=0
fi
echo
# TBD try to boot directly from kernel/initrd within the ISO via the grub2 loop module
search -s -f -n /ubuntu/install/boot/vmlinuz.efi
menuentry "Normal mode" {
linux /ubuntu/install/boot/vmlinuz.efi debian-installer/custom-installation=/ubuntu/install/custom-installation iso-scan/filename=/ubuntu/install/ubuntu-14.10-desktop-amd64.iso automatic-ubiquity noprompt quiet splash boot=casper ro debian-installer/locale=zh_CN.UTF-8 keyboard-configuration/layoutcode=us keyboard-configuration/variantcode= -- rootflags=sync
initrd /ubuntu/install/boot/initrd.lz
menuentry "Safe graphic mode" {
linux /ubuntu/install/boot/vmlinuz.efi debian-installer/custom-installation=/ubuntu/install/custom-installation iso-scan/filename=/ubuntu/install/ubuntu-14.10-desktop-amd64.iso automatic-ubiquity noprompt debug debug-ubiquity xforcevesa boot=casper ro debian-installer/locale=zh_CN.UTF-8 keyboard-configuration/layoutcode=us keyboard-configuration/variantcode= -- rootflags=sync
menuentry "ACPI workarounds" {
linux /ubuntu/install/boot/vmlinuz.efi debian-installer/custom-installation=/ubuntu/install/custom-installation iso-scan/filename=/ubuntu/install/ubuntu-14.10-desktop-amd64.iso automatic-ubiquity noprompt debug debug-ubiquity boot=casper ro debian-installer/locale=zh_CN.UTF-8 keyboard-configuration/layoutcode=us keyboard-configuration/variantcode= -- rootflags=sync acpi=off noapic nolapic
menuentry "Verbose mode" {
menuentry "Demo mode" {
linux /ubuntu/install/boot/vmlinuz.efi iso-scan/filename=/ubuntu/install/ubuntu-14.10-desktop-amd64.iso quiet splash boot=casper ro debian-installer/locale=zh_CN.UTF-8 keyboard-configuration/layoutcode=us keyboard-configuration/variantcode= -- rootflags=sync
