# dpkg -i gfortran-4.4-multilib_4.4.7-8ubuntu1_i386.deb
(Reading database ... 176046 files and directories currently installed.)
Preparing to unpack gfortran-4.4-multilib_4.4.7-8ubuntu1_i386.deb ...
Unpacking gfortran-4.4-multilib (4.4.7-8ubuntu1) over (4.4.7-8ubuntu1) ...
dpkg: dependency problems prevent configuration of gfortran-4.4-multilib:
gfortran-4.4-multilib depends on gcc-4.4-base (= 4.4.7-8ubuntu1); however:
Package gcc-4.4-base is not installed.
gfortran-4.4-multilib depends on gfortran-4.4 (= 4.4.7-8ubuntu1); however:
Package gfortran-4.4 is not installed.
gfortran-4.4-multilib depends on gcc-4.4-multilib (= 4.4.7-8ubuntu1); however:
Package gcc-4.4-multilib is not installed.
gfortran-4.4-multilib depends on lib64gfortran3 (>= 4.4.7-8ubuntu1); however:
Package lib64gfortran3 is not installed.
dpkg: error processing package gfortran-4.4-multilib (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
dpkg安装deb文件,但依赖太多,各位大神是怎么解决的
- 系统: ubuntu10.04
- 九天星
Re: dpkg安装deb文件,但依赖太多,各位大神是怎么解决的
sudo apt install -f
- 系统: ubuntu10.04
试过了,还是不行九天星 写了:代码: 全选
sudo apt install -f
- 系统: ubuntu10.04
# sudo apt install -f九天星 写了:代码: 全选
sudo apt install -f
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... failed.
The following packages have unmet dependencies:
gfortran-4.4-multilib : Depends: gcc-4.4-base (= 4.4.7-8ubuntu1) but it is not installed
Depends: gfortran-4.4 (= 4.4.7-8ubuntu1) but it is not installed
Depends: gcc-4.4-multilib (= 4.4.7-8ubuntu1) but it is not installed
Depends: lib64gfortran3 (>= 4.4.7-8ubuntu1) but it is not installed
libblas-dev : Depends: libblas3 (= 1.2.20110419-7) but it is not installed
libc6-dbg : Depends: libc6 (= 2.19-0ubuntu6.5) but 2.19-0ubuntu6 is installed
libc6-dev : Depends: libc-dev-bin (= 2.19-0ubuntu6) but 2.19-0ubuntu6.5 is installed
zlib1g-dev : Depends: zlib1g (= 1:1.2.3.4.dfsg-3ubuntu4) but 1:1.2.8.dfsg-1ubuntu1 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
1. 這個指令 還不夠聰明到解決所有相依未滿足的情況 手動介入 有時還是需要的sudo apt install -f
2. https://packages.ubuntu.com/search?suit ... chon=namesdpkg -i gfortran-4.4-multilib_4.4.7-8ubuntu1_i386.deb
Package gfortran-4.4-multilib
3. 把下面指令 複製 貼進終端機 執行
3-1. uname -a
3-2. sudo cat /etc/os-release | grep VERSION
把指令及結果全部直接 選取/複製/貼上來
- 系统: ubuntu10.04
感谢回复,我一个依赖一个依赖装的poloshiao 写了:1. 這個指令 還不夠聰明到解決所有相依未滿足的情況 手動介入 有時還是需要的sudo apt install -f2. https://packages.ubuntu.com/search?suit ... chon=namesdpkg -i gfortran-4.4-multilib_4.4.7-8ubuntu1_i386.deb
3-1. uname -a
- susbarbatus
- 系统: Arch Linux
3-1. uname -a
你的回答 並沒有針對我的問題感谢回复,我一个依赖一个依赖装的
