发表新帖 回复这个主题  [ 1 篇帖子 ]
 文章标题 : Working lua and pointing LIBS to it
帖子发表于 : 2018-01-05 15:25
注册: 2018-01-05 15:19
系统: Ubuntu
configure: - P4EST -------------------------------------------------
We did not find a recent lua containing the function lua_createtable.
This is OK if the following does not matter to you:
Including sc_lua.h in your code will abort the compilation.
You can fix this by compiling a working lua and pointing LIBS to it.
When i install P4EST, the words above occur. And what can i do to "Working lua and pointing LIBS to it"
I am not quite understand. Any one help??
正在浏览此版面的用户:没有注册用户 和 1 位游客
