xiaoli@xiaoli-X455LJ:~$ sudo aria2c --conf-path=/etc/aria2/aria2.conf:
08/09 20:53:33 [WARN] Neither --rpc-secret nor a combination of --rpc-user and --rpc-passwd is set. This is insecure. It is extremely recommended to specify --rpc-secret with the adequate secrecy or now deprecated --rpc-user and --rpc-passwd.
08/09 20:53:33 [ERROR] IPv4 RPC: failed to bind TCP port 6800
Exception: [SocketCore.cc:312] errorCode=1 绑定套接字失败,原因:地址已在使用
08/09 20:53:33 [ERROR] 捕捉到异常
Exception: [DownloadEngineFactory.cc:219] errorCode=1 Failed to setup RPC server.
安装了Aria2 一直都设置不对!
