来个复杂点的游戏 够你玩上好一阵子 (维多利亚2)
- ReiFFEXzyx
Paradox的 Victoria II(维多利亚2)
大型策略类游戏,上手比较难
想玩得深入,没几个星期恐怕不行...
winehq的安装提示
http://appdb.winehq.org/objectManager.p ... ngId=56100
What works
Installation Single player
What does not
Music doesn't work, though sounds work fine.
What was not tested
Multiplayer
Additional Comments
This is how to install it:
1. Install only the game, cancel VC Runtime, cancel .NET and cancel DirectX
2. winetricks winxp dotnet20 d3dx9 vcrun2005 vcrun2005sp1
3. Go to windows/system32 and remove: msvcr80.dll
4. Go to Porgram Files/Paradox Interactive/Victoria 2/ and remove lua51.dll and lua5.1.dll
5. Download
http://code.google.com/p/luaforwindows/ ... .exe&can=2 and install it with wine.
6. Run wine regedit and create these keys/vales: (this should fix the Loading Flags problem.)
In HKCU/Software/Wine/Direct3D/
DirectDrawRenderer to "opengl"
OffscreenRenderingMode to "backbuffer"
PixelShaderMode to "enabled"
VideoMemorySize to the size of your video memory (e.g. "512")
In HKCU/Software/Wine/DirectSound/
MaxShadowSize to "0"
7. wineboot
8. Run the game with: wine v2game.exe
截图
大型策略类游戏,上手比较难
想玩得深入,没几个星期恐怕不行...
winehq的安装提示
What works
What does not
What was not tested
Multiplayer
Additional Comments
5. Download
7. wineboot
截图
- snowtown86
- Sucrose
- ReiFFEXzyx
Re: 来个复杂点的游戏 够你玩上好一阵子 (维多利亚2)
转自winehq 我自己没试过...Sucrose 写了:看来我wine钢铁雄心III有望了
http://appdb.winehq.org/objectManager.p ... ngId=43730
1. Install the game, recommended creating new wineprefix
Change to cd folder and run in terminal:
env "WINEPREFIX=$HOME/.wine-hoi3" wine Setup.exe
2. Install the game, cancel installation of .NET Framework 2.0, Install MSVC, cancel installation of DirectX
3. Download winetricks and run
env "WINEPREFIX=$HOME/.wine-hoi3" sh winetricks directx9 dotnet20
4. Run
env "WINEPREFIX=$HOME/.wine-hoi3" regedit
add new keys to HKEY_CURRENT_USER/Software/Wine and name it Direct3D and Directsound. Set new strings:
in Direct3D
- DirectDrawRenderer to opengl
- OffscreenRenderingMode to backbuffer
- PixelShaderMode to enabled
- VideoMemorySize to 512
in Directsound
- MaxShadowSize to 0
5. Install patch 1.1
6. Change to game folder, run
env "WINEPREFIX=$HOME/.wine-hoi3" wine hoi3game.exe
and enjoy the game
- 来自: 福州
还是喜欢钢铁雄心
- leni
测略类游戏还不太会玩
- walker4
mark 游戏不错~
- 吴广德
- 系统: Ubuntu 18.04 LTS
- 来自: 中国-广西-南宁
EU2可以完美模拟,但EU3有点麻烦……
Ubuntu 18.04 LTS使用中......
主板:MSI Z97 gaming 9 ACK
CPU:I7 4790K
内存:DDR3 8G x 4 = 32G
硬盘:60G SSD(/) + 1T HD(/home)
显示器:Philips 274E5Q
CPU:I7 4790K
显示器:Philips 274E5Q
- lm789632
- 系统: UBUNTU 12.10
- 来自: HELL
- nyfair
- 系统: winnux10
- 来自: Tree New Bee
维多利亚ai不算高,eu3的mmu才叫疯狂啊
本人在此论坛仅负责吐槽,问题急需解决请支付宝转账5毛至{我的id@qq.com},将会竭诚为您服务
linux常见多媒体问题处理指南
1. 视频播放有问题->卸载gstreamer
2. 音频播放有问题->卸载pulseaudio
3. 远程播放有问题->卸载avahi
4. 系统全都有问题->卸载systemd,远离Lennart这傻逼让你从此轻松自在
⇩自由网络⇩
https://github.com/nyfair/freeweb
linux常见多媒体问题处理指南
3. 远程播放有问题->卸载avahi
⇩自由网络⇩
- mark1991
维多利亚2 钢铁雄心3 欧陆风云3, 我都不知道玩哪个好了... 之前很少玩策略游戏的,但是现在想尝试一下. 我觉得吧,我还是比较喜欢打仗的那种类型,不那么喜欢搞生产, 请问,这三款游戏里面哪个比较适合我?
- mark1991
哎呀,本来可以玩了,后来把安装步骤第5条装的那个 lua 给重装了一次,就又不能玩了… 说是找不到msvcr80.dll之类的,就好像第5条装的那个lua没有被识别的感觉… 请问,我该如何处理?
- ReiFFEXzyx
我装好后,简单看了下,就没再玩了
从第3步再来一遍试试
从第3步再来一遍试试
- ReiFFEXzyx
Paradox的游戏都很类似mark1991 写了:维多利亚2 钢铁雄心3 欧陆风云3, 我都不知道玩哪个好了... 之前很少玩策略游戏的,但是现在想尝试一下. 我觉得吧,我还是比较喜欢打仗的那种类型,不那么喜欢搞生产, 请问,这三款游戏里面哪个比较适合我?
喜欢打仗的话试试“文明5”
文明5光盘版wine起来非常方便
Windows下安装一遍、Linux下安装一遍到同一目录
升级补丁直接在Windows下打
回到Linux下可以同一版本一起玩(仅存档、设定位置不同)
- 来自: 福州
对wine似乎不怎么喜欢了
