 文章标题 : STEAM安裝了,但是啓動不了
帖子发表于 : 2016-05-21 17:20
注册: 2016-05-13 17:23
系统: Ubantu和win10双系统
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
[2016-05-21 17:24:18] Startup - updater built Apr 29 2016 22:18:33
SteamUpdateUI: An X Error occurred
X Error of failed request: BadValue (integer parameter out of range for operation)
求大神看看怎麼解決?我已經沒轍了。
 文章标题 : Re: STEAM安裝了,但是啓動不了
帖子发表于 : 2016-05-21 18:03
看看 有没有帮助
https://github.com/ValveSoftware/steam-for-linux/issues/3820
This problem is due to some outdated libraries in the steam folder.
While the steam team update them, the solution is to delete them
(so steam will take them from the system).
帖子发表于 : 2016-05-24 21:34
注册: 2016-05-24 21:20
系统: ubuntu 16.04
grep: symbol lookup error: grep: undefined symbol: pcre_jit_stack_alloc
Installing breakpad exception handler for appid(steam)/version(1461972496)
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
有遇到这种问题的没
正在浏览此版面的用户:没有注册用户 和 5 位游客
