求助笔记本安装Ubuntu16.04之后的驱动问题
声卡/显卡/打印机/USB设备等硬件问题(网卡问题请发上面的网卡板块)
itqmdx
系统: ubuntu 16.04
帖子 itqmdx » 2018-04-15 14:27
我的笔记本是ThinkPad T470p 最近安装Ubuntu16.04.4之后驱动有些没有安装:
我算是一个linux菜鸟,不知道有什么更好的方法可以查询驱动问题,我知道的只有
lspci -vvv
如果有还请大家告知..
下面是我的驱动信息:
wzhz@ThinkPad-T470p:~$ lspci -vvv
00:00.0 Host bridge: Intel Corporation Device 5910 (rev 05)
	Subsystem: Lenovo Device 505d
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
	Latency: 0
	Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 120
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 0000f000-00000fff
	Memory behind bridge: fff00000-000fffff
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:01.2 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x4) (rev 05) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 121
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: f1000000-f1ffffff
	Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04) (prog-if 00 [VGA controller])
	Subsystem: Lenovo Device 505e
	Latency: 0
	Interrupt: pin A routed to IRQ 128
	Region 0: Memory at f0000000 (64-bit, non-prefetchable) [size=16M]
	Region 2: Memory at e0000000 (64-bit, prefetchable) [size=256M]
	Region 4: I/O ports at e000 [size=64]
	[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
	Kernel driver in use: i915
	Kernel modules: i915
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
	Subsystem: Lenovo Sunrise Point-H USB 3.0 xHCI Controller
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 124
	Region 0: Memory at f2220000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
	Subsystem: Lenovo Sunrise Point-H Thermal subsystem
	Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin C routed to IRQ 18
	Region 0: Memory at f224a000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: intel_pch_thermal
	Kernel modules: intel_pch_thermal
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
	Subsystem: Lenovo Sunrise Point-H CSME HECI
	Latency: 0
	Interrupt: pin A routed to IRQ 129
	Region 0: Memory at f224b000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Sunrise Point-H SATA Controller [AHCI mode] (rev 31) (prog-if 01 [AHCI 1.0])
	Subsystem: Lenovo Sunrise Point-H SATA Controller [AHCI mode]
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 126
	Region 0: Memory at f2248000 (32-bit, non-prefetchable) [size=8K]
	Region 1: Memory at f224e000 (32-bit, non-prefetchable) [size=256]
	Region 2: I/O ports at e080 [size=8]
	Region 3: I/O ports at e088 [size=4]
	Region 4: I/O ports at e060 [size=32]
	Region 5: Memory at f224c000 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 122
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	Memory behind bridge: f2100000-f21fffff
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #5 (rev f1) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 123
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	Memory behind bridge: f2000000-f20fffff
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
	Subsystem: Lenovo Sunrise Point-H LPC Controller
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
	Subsystem: Lenovo Sunrise Point-H PMC
	Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Region 0: Memory at f2244000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device: Intel Corporation Device a171 (rev 31)
	Latency: 64
	Interrupt: pin A routed to IRQ 131
	Region 0: Memory at f2240000 (64-bit, non-prefetchable) [size=16K]
	Region 4: Memory at f2230000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
	Subsystem: Lenovo Sunrise Point-H SMBus
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 255
	Region 0: Memory at f224d000 (64-bit, non-prefetchable) [disabled] [size=256]
	Region 4: I/O ports at efa0 [disabled] [size=32]
	Kernel modules: i2c_i801
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (5) I219-V (rev 31)
	Subsystem: Lenovo Ethernet Connection (5) I219-V
	Latency: 0
	Interrupt: pin A routed to IRQ 127
	Region 0: Memory at f2200000 (32-bit, non-prefetchable) [size=128K]
	Kernel driver in use: e1000e
	Kernel modules: e1000e
02:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev a2)
	Subsystem: Lenovo GM108M [GeForce 940MX]
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin A routed to IRQ 18
	Region 0: Memory at f1000000 (32-bit, non-prefetchable) [size=16M]
	Region 1: Memory at c0000000 (64-bit, prefetchable) [size=256M]
	Region 3: Memory at d0000000 (64-bit, prefetchable) [size=32M]
	Region 5: I/O ports at d000 [size=128]
	Expansion ROM at <ignored> [disabled]
	Kernel modules: nvidiafb, nouveau, nvidia_304
03:00.0 Network controller: Intel Corporation Device 24fd (rev 78)
	Subsystem: Intel Corporation Device 1010
	Latency: 0
	Interrupt: pin A routed to IRQ 130
	Region 0: Memory at f2100000 (64-bit, non-prefetchable) [size=8K]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
	Subsystem: Lenovo RTS522A PCI Express Card Reader
	Latency: 0
	Interrupt: pin A routed to IRQ 125
	Region 0: Memory at f2000000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: rtsx_pci
	Kernel modules: rtsx_pci
其中我看到有几个是没有安装驱动程序的:
	Latency: 0
	Latency: 0
请问大家,应该如何安装未安装的驱动.
richardday
Re: 求助笔记本安装Ubuntu16.04之后的驱动问题
帖子 richardday » 2018-04-15 17:22
试试linuxmint看看 :Haha
itqmdx
系统: ubuntu 16.04
帖子 itqmdx » 2018-04-15 19:49
richardday 写了:试试linuxmint看看 :Haha
linuxmint可以安装上面的驱动么?
回到 “常用硬件支持”
