发表新帖 回复这个主题  [ 2 篇帖子 ]
 文章标题 : tftp服务 报错
帖子发表于 : 2017-12-10 14:16
注册: 2013-01-26 14:09
$systemctl status tftpd-hpa.service
● tftpd-hpa.service - LSB: HPA's tftp server
Loaded: loaded (/etc/init.d/tftpd-hpa; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since 日 2017-12-10 14:10:25 CST; 14s ago
Docs: man:systemd-sysv-generator(8)
Process: 3990 ExecStop=/etc/init.d/tftpd-hpa stop (code=exited, status=0/SUCCESS)
Process: 4022 ExecStart=/etc/init.d/tftpd-hpa start (code=exited, status=71)
12月 10 14:10:25 du-T6-3 systemd[1]: Starting LSB: HPA's tftp server...
12月 10 14:10:25 du-T6-3 tftpd-hpa[4022]: * Starting HPA's tftpd in.tftpd
12月 10 14:10:25 du-T6-3 systemd[1]: tftpd-hpa.service: Control process exited, code=exited status=71
12月 10 14:10:25 du-T6-3 systemd[1]: Failed to start LSB: HPA's tftp server.
12月 10 14:10:25 du-T6-3 systemd[1]: tftpd-hpa.service: Unit entered failed state.
12月 10 14:10:25 du-T6-3 systemd[1]: tftpd-hpa.service: Failed with result 'exit-code'
 文章标题 : Re: tftp服务 报错
帖子发表于 : 2017-12-10 22:03
注册: 2008-09-18 13:11
接收感谢: 457
systemctl restart tftpd-hpa.service
journalctl -xe
看具体的错误信息
