怎样手工建立交换文件?
百草谷居士
系统: Mint21.1/Deepin20.8
怎样手工建立交换文件?
帖子 百草谷居士 » 2018-06-12 8:57
如果是在新安装ubuntu1804时,没有划出交换分区,系统会自动启用交换文件来替代交换分区,这也是Ubuntu现在推荐的方式。
可是问题是这样的,我在安装ubuntu1804时,已经存在交换分区了,现在又把交换分区删了,又不想重新安装,那么,如何手工建立交换文件并启用这种模式呢?
debian 12 / 深度系统 20.9 / Mint 21.3
Re: 怎样手工建立交换文件?
帖子 astolia » 2018-06-12 9:32
又上不了google了? https://help.ubuntu.com/community/SwapF ... ap_file.3F
Create the Swap File:
We will create a 1 GiB file (/mnt/1GiB.swap) to use as swap:
sudo fallocate -l 1g /mnt/1GiB.swap
fallocate size suffixes: g = Giga, m = Mega, etc. (See man fallocate).
If fallocate fails or it not available, you can use dd:
sudo dd if=/dev/zero of=/mnt/1GiB.swap bs=1024 count=1048576
We need to set the swap file permissions to 600 to prevent other users from being able to read potentially sensitive information from the swap file.
sudo chmod 600 /mnt/1GiB.swap
Format the file as swap:
sudo mkswap /mnt/1GiB.swap
Enable use of Swap File
sudo swapon /mnt/1GiB.swap
The additional swap is now available and verified with: cat /proc/swaps
Enable Swap File at Bootup
Add the swap file details to /etc/fstab so it will be available at bootup:
echo '/mnt/1GiB.swap swap swap defaults 0 0' | sudo tee -a /etc/fstab
Example of making a swap file
This is an example of making and using a swap file on a computer with no swap partition.
$ sudo fallocate -l 1g /mnt/1GiB.swap
$ sudo chmod 600 /mnt/1GiB.swap
$ sudo mkswap /mnt/1GiB.swap
Setting up swapspace version 1, size = 1048576 kB
$ sudo swapon /mnt/1GiB.swap
$ cat /proc/swaps
Filename                                Type            Size    Used    Priority
/home/swapfile                          file            1048576 1048576 -1
$ echo '/mnt/4GiB.swap swap swap defaults 0 0' | sudo tee -a /etc/fstab
$ reboot
$ free -h
              total        used        free      shared  buff/cache   available
Mem:            15G        9.3G        454M        4.0G        5.8G        1.9G
Swap:          1.0G        1.0G          0B
百草谷居士
Re: 怎样手工建立交换文件?
帖子 百草谷居士 » 2018-06-12 9:52
谢谢,我将交换文件设置为4G。好像用不到啊!
free -h
$ free -h
总计 已用 空闲 共享 缓冲/缓存 可用
内存: 7.7G 760M 6.0G 202M 1.0G 6.5G
交换: 4.0G 0B 4.0G
swapon
$ swapon
NAME TYPE SIZE USED PRIO
/home/4G.swap file 4G 0B -2
Re: 怎样手工建立交换文件?
帖子 astolia » 2018-06-12 10:11
有那么多快速的内存空着,干嘛要用慢的要死的交换文件?
非要玩的话
sudo sysctl vm.swappiness=100
dd if=/dev/urandom of=/dev/shm/test bs=1M
男菜鸟
来自: 漂在江湖
Re: 怎样手工建立交换文件?
帖子 男菜鸟 » 2018-06-13 22:49
mark
百草谷居士
Re: 怎样手工建立交换文件?
帖子 百草谷居士 » 2018-06-14 14:11
我看了一下如果安装时没有交换分区,系统自设的交换文件在fstab文件的定义,是这样的:
swapfile none swap sw 0 0
swapfile 位于根节点。后面的选项还是有区别的。
tang.zhe
Re: 怎样手工建立交换文件?
帖子 tang.zhe » 2018-06-15 7:45
:em11
速腾1994
系统: Arch+gnome
Re: 怎样手工建立交换文件?
帖子 速腾1994 » 2018-06-19 22:15
swap是不需要手动挂载的。只要有swap分区,系统会自动挂载的
